[mapguide-users] Re: MSSQL 2008 R2 and MGOS 2.2
Martin Morrison martin.morrison at edsi.com
Tue Jul 26 08:50:00 EDT 2011
Shape vs SQL server shouldn't make any difference to MapGuide since you are actually using FDO.  Can you manually add the SQL data with either Studio or Maestro?  If not, get that working first.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of anand
Sent: Tuesday, July 26, 2011 2:31 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: MSSQL 2008 R2 and MGOS 2.2
hi,
I'm using Mapguide OpenSource 2.1 (with .net 2.0 +IIS 5.1). i have a polygon
layer loaded on the map whose spatial data is coming from Sql server 2008.
Now i want to select a particular polygon (for ex: parcel_id=222) on the map
programmatically and i want to change the color of polygon. When i create my
map with shape files everything works fine, but when i create the map by
getting spatial data from sql server 2008 it doesn't work. Can anybody tell
me what mistake am i doing?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MSSQL-2008-R2-and-MGOS-2-2-tp6604255p6621139.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
