[mapguide-users] Re: Using MG_DATA_PATH_ALIAS
Steve G steve.golden at morganhill.ca.gov
Wed Jun 29 16:39:22 EDT 2011
I added to the Mapguide Wiki.  See:
http://trac.osgeo.org/mapguide/wiki/ConfiguringAliases
Also, there is a white paper document from Autodesk which I found (will add
to the wiki page momentarily).  It's a bit old but I think still relevant to
all versions of MapGuide MGOS 2.x:
http://images.autodesk.com/adsk/files/linking_to_external_data_autodeskmapguidewhitepaper.pdf
Dave, if you can post back the full xml, per above instructions, maybe there
is something else missing...
-Steve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-MG-DATA-PATH-ALIAS-tp6511919p6530634.html
