[mapguide-users] Secure mapagent
Zac Spitzer zac.spitzer at gmail.com
Tue Mar 1 07:43:17 EST 2011
You can remove it or use normal webserver approaches.
It's just mostly HTML wrappers for standard calls.
Login is required for everything bar a few hardwired default admin passwords
I.e. admin (I think) which you should always change
On Mar 1, 2011 10:07 PM, "mhanu70" <emanuele.pascariello at gmail.com> wrote:
> Hello i've noted that the url
> http://localhost/mapguide/mapagent/index.html
> is not secured. indeed a login is not required to access it.
> is that any way to secure with a login request?
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110301/99bea412/attachment.html
