[mapguide-users] RE: Compile Error: An attempt was made to load a program with an incorrect format.
airfiol jllj3 at hotmail.com
Thu Mar 10 11:22:16 EST 2011
The web application project is set to compile as a 64 bit application and the
AppPool is set to use DotNet 2.0 and "Enable 32 bit applications =  False.
The error is occuring when I attempt to compile. Unless I'm mistaken, IIS
settings don't come into play until after the application compiles
successfully.
I ran the corflags.exe as suggested but I'm not sure how to interpret them.
Please see below. Does 32BIT:0 mean that they are 64bit?
corflags.exe "C:\Program
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\MapGuideDotNetApi.dll"
Version   : v2.0.50727
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\OSGeo.MapGuide.Foundation.dll"
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\OSGeo.MapGuide.Geometry.dll"
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\OSGeo.MapGuide.MapGuideCommon.dll"
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\OSGeo.MapGuide.PlatformBase.dll"
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
Files\OSGeo\MapGuide\Web\www\mapviewernet\bin\OSGeo.MapGuide.Web.dll"
CLR Header: 2.5
PE        : PE32+
CorFlags  : 1
ILONLY    : 1
32BIT     : 0
Signed    : 0
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp6153978p6158323.html
