[mapguide-users] MapGuide Maestro 3.0 beta 1 now available
Haris Kurtagic haris at sl-king.com
Fri Mar 11 06:27:47 EST 2011
Thanks Jackie
2011/3/8 Ivan Miličević <Ivan.Milicevic at supranet.hr>:
> Jackie the King! Thank you!
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, March 08, 2011 2:45 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MapGuide Maestro 3.0 beta 1 now available
> Hi All,
> After 10 months of on/off development, I am happy to announce the 1st beta release of MapGuide Maestro 3.0:
> NSIS installer:
> http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-Release-3.0b1-Setup.exe
> Zip package:
> http://download.osgeo.org/mapguide/maestro/MapGuideMaestro-3.0b1-Release.zip
> First thing to remember is that this is a beta release. This release should be used for testing purposes and feedback. Use for production purposes at your own risk.
> Some of the new stuff (from Test Build 4):
>  - Implemented specialized GDAL raster feature source editor
>  - Implemented specialized ODBC feature source editor
>  - Implemented widget management for Fusion editor
>  - Implemented Raster Layer Editor (ported over from 2.x)
>  - Add support for viewing Feature Source cache information (via the GETFDOCACHEINFO mapagent call)
> These newly implemented features require some extensive testing, especially in Mono
> As I've mentioned with previous test builds, some general notes when testing this build:
>  - Found a bug? Ask yourself: Did this bug exist in Maestro 2.x, and hence is a known problem?
>  - Similarly, that Maestro 2.x issue you filed in Trac some time ago: Has it been fixed or successfully worked around with this release?
>  - So generally speaking, it really helps to have an existing installation of Maestro 2.x on hand (current release being 2.1.4) as a baseline comparison to whether something has been fixed or broken.
>  - Filed an issue under the previous test build or beta? Did this release fix this issue for you?
>  - All existing Maestro tickets will be re-targeted to the maestro-3.0 milestone
>  - Something breaks when running in Mono? It helps to specify the expected behaviour when running in Windows. Screenshots help as well. Also indicate the version of Mono
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-Maestro-3-0-beta-1-now-available-tp6125249p6125249.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
