[mapguide-users] MapGuide Open Source 2.2 Release Candidate 4 released
Steve Finch steve.finch at edsi.com
Mon Mar 21 10:17:53 EDT 2011
I'm the one that posted about the IE9 problems.  I'm testing MGOS 2.2.0.5354 using the AJAX viewer with the RTM version of IE9 (9.0.8112.16421).  Without compatibility mode turned on, the site is broken as described before.   Features cannot be selected, drop-downs on the taskbar don't work, and the rendering of the drop-downs on the taskbar is incorrect.
Whether we like it or not, our sites will be hit by large numbers of using running IE9 very soon.  Thankfully, there's a workaround by forcing compatibility mode, but it would sure be great to not have to use that.  Of course, Firefox 4 release is coming soon, along with the new version of Chrome.
Steve
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew DeMerchant
Sent: Saturday, March 19, 2011 2:29 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MapGuide Open Source 2.2 Release Candidate 4 released
I'm not setup to build - so I can't do any patching...I could certainly do some testing though, if someone could get me a test build.
In other news, I just installed IE9 and tested out on my server which is running MGOS v2.2.0.5354 (I think that's RC2)....worked perfectly fine for me. My site's AJAX though - could be that the guy that posted about this problem was either a) using Fusion (which I can't test right now, since I don't have any Fusion sites), or b) had a beta of IE9 which was, indeed, broken.....or maybe c) that the version after 2.2.0.5354 breaks
IE9 compatibility, I suppose. Though, that seems unlikely.
Anyway - I just wanted to give my 2cents on this...I just think that we should make sure that either MGOS 2.2 supports all major browsers out of the box, or else gets a patch asap - I'm not sure when IE9 will be pushed out through Windows Update and WSUS, but when it does, we need to be sure that MGOS is up to snuff for it.....like I said, from what I can tell at the moment, it seems to work fine (or worst case, worked fine very recently).
Andrew
On 19/03/2011 11:53 AM, Zac Spitzer wrote:
> Alas. the ie9 fixes were made on trunk 4 months ago
> http://trac.osgeo.org/mapguide/search?q=ie9&noquickjump=1&changeset=on
> I believe the 2.2 branch was cut 5 months ago
> Andrew, can you apply and test those change sets over a RC4 install?
> z
> On Sun, Mar 20, 2011 at 12:42 AM, Trevor Wekel
> <trevor_wekel at otxsystems.com>  wrote:
>> Hi Andrew,
>> I believe there are some IE9 fixes present in the RC4 build and likely more to come.  I was not planning on holding back the 2.2.0 release for IE9 support.  I do agree it is an important feature.  We are already thinking about timing and content for a 2.2.1 bug fix release.
>> Bug fix release?  What's that?  We haven't had one of those since 2.0.2 (2.5 years ago).  Most open source projects have bug fix releases every quarter.  Releases and bug fixes are certainly one area where funding either by direct contract work or through Sponsorships/Donations would certainly help.
>> At the moment, we barely manage a single release every year.  The 2.2.0 release has been especially troublesome.  We've generated four release candidates since October.
>> Regards,
>> Trevor
>> DeMerchant
>> Sent: March 19, 2011 7:16 AM
>> Does this RC fix the IE9 problems? I recall reading something on the list that someone had posted about how Mapguide pretty much doesn't work with IE9....Since it's out now, MGOS 2.2 really needs to support it fully. Anyway, just wonrdering! I haven't had a chance to test it out myself quite yet...
>> Andrew
>> On 18/03/2011 10:06 PM, Zac Spitzer wrote:
>>> Just to Clarify,
>>> If you find a defect, please only report it using trac, AFTER first
>>> posting to the mailing list and having the issue confirmed
>>> Regards
>>> Zac
>>> On Sat, Mar 19, 2011 at 4:41 AM, Trevor Wekel
>>>> We are pleased to announce that the MapGuide Open Source project team has made MapGuide Open Source 2.2 Release Candidate 4 available.
>>>> Release notes:
>>>> http://trac.osgeo.org/mapguide/wiki/Release/2.2RC4/Notes
>>>> Downloads:
>>>> http://trac.osgeo.org/mapguide/wiki/Release/2.2RC4/Notes#Installati
>>>> on
>>>> Documentation: Please continue to use the 2.0 documentation for now. The release notes contain information on API changes between MapGuide 2.1 and MapGuide 2.2.
>>>> If you find a defect, please report it using trac.
>>>> Thanks to the ever growing team of developers who are contributing to make the MapGuide Open Source project a more self-sustaining project.
>>>> Regards,
>>>> The MapGuide PSC
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
