[mapguide-users] Re: blinking object in mapguide
Jackie Ng jumpinjackie at gmail.com
Tue May 3 02:07:25 EDT 2011
That is not possible in the traditional sense.
What you can probably do however, if you're using Fusion is to insert an
OpenLayers marker into your map (at the landslide location), using an
animated gif as your marker image.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/blinking-object-in-mapguide-tp6326227p6326239.html
