[mapguide-users] IE + Fusion +Java applet problem
Zac Spitzer zac.spitzer at gmail.com
Wed May 18 03:31:24 EDT 2011
have you tried using a different java simple applet as test?
2011/5/18 Turcsanyi Zoltan <zolinko at freemail.hu>:
> Hi,
> I have a problem with mapgide fusion:
> When I use Fusion viewer and a Java applet at the same time in an HTML page,
> under Internet Explorer Fusion gets freezed every time I do an action on the map (zoom, pan, etc.).
> When I move the mouse out of the map area, Fusion continues to do the work and does it well.
> But when I move the mouse over the map area again, fusion gets freezed again: any action requested is freezed until I move the mouse out of the map area.
> When the applet isn't visible (scrolled out of the screen on large HTML page), Fusion works perfectly, but when the applet gets visible again (even 1 pixel of it), Fusion gets freezed again.
> In the case when the Java applet is visible, and when I move the mouse over the map area, also the processor speed jumps up to 50-70-100%. When the applet isn't visible, this doesn't happen, processor speed remains around 0%.
> This only happens under Internet Explorer (version 8 and 9 were tested) and with any Java applet (I tested with an applet contains a simple panel with no events). I also tried to embed the applet with two methods: applet and object tag, and the problem accurs with both methods. I also tried with different operating systems: Xpsp3 and Win7.
> If you have any idea, it will be appreciated,
> thx
> zoli...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
