[mapguide-users] Re: FDO Toolbox Connection
Martin Morrison martin.morrison at edsi.com
Fri May 27 14:10:23 EDT 2011
2005 does not have the ability to store geometry/geography objects (you can store xy fields though).  In my OPINION, you should upgrade to SQL server 2008 so you can store the geometry and the data in the same database.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of yash227
Sent: Friday, May 27, 2011 8:15 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: FDO Toolbox Connection
We can easily do that.We can accommodate all require data to generate map in
the SHP itself but in that case it want remain dynamic...which is very much
needed in our case.
We want to update the data in sql 2005 and it should be reflect in map.
Thanks.
Yash.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Toolbox-Connection-tp6410463p6410836.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
