[mapguide-users] mapagent crashes
Zac Spitzer zac.spitzer at gmail.com
Fri May 27 23:20:59 EDT 2011
Can you describe your map? What FDO datasources are being used.
Have a look at both your webserver and mapguide server logs
for error messages and post those errors back to the list?
So it's only the webserver crashes and not the mapguide server process?
Does the problem only occur at a certain scale range?
z
On Fri, May 27, 2011 at 9:38 PM, vd <vd at plan-online.info> wrote:
> Hi,
> We ordered some security checks and one of the results was:
> The webserver crashes if you send a request like:
> http://yourserver/mapguide/mapagent/mapagent.fcgi?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=70c85ffc-8760-11e0-8000-00237deca616_en_7F0000010AFC0AFB0AFA&MAPNAME=map&SEQ=0.23651071377519906&CLIENTAGENT=Ajax%20Viewer&BEHAVIOR=2&SETDISPLAYDPI=96&SETDISPLAYWIDTH=474&SETDISPLAYHEIGHT=444&SETVIEWSCALE=175421.11033589157&SETVIEWCENTERX=3549113%a5'%20having%201=1--&SETVIEWCENTERY=5805500&CLIENTAGENT=Ajax%20Viewer<http://yourserver/mapguide/mapagent/mapagent.fcgi?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=70c85ffc-8760-11e0-8000-00237deca616_en_7F0000010AFC0AFB0AFA&MAPNAME=map&SEQ=0.23651071377519906&CLIENTAGENT=Ajax%20Viewer&BEHAVIOR=2&SETDISPLAYDPI=96&SETDISPLAYWIDTH=474&SETDISPLAYHEIGHT=444&SETVIEWSCALE=175421.11033589157&SETVIEWCENTERX=3549113%a5%27%20having%201=1--&SETVIEWCENTERY=5805500&CLIENTAGENT=Ajax%20Viewer>
> Apache crashes at the first request, IIS after 7 to 10 requests.
> We use MGOS 2.2
> Windows Server 2003 SP2
> Apache 2.2
> http://osgeo-org.1803224.n2.nabble.com/mapagent-crashes-tp6410737p6410737.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110528/bb445080/attachment.html
