[mapguide-users] Re: Google Chrome & AJAX Viewer
Zac Spitzer zac.spitzer at gmail.com
Fri Nov 4 00:00:14 EDT 2011
try comparing using winmerge
On Fri, Nov 4, 2011 at 1:40 PM, Denis Lalonde <denlalonde at gmail.com> wrote:
> Thanks for that. Unfortunately, I did mess around (a lot) with files in both
> those directories. I'm paying for that now eh?
> Oh well, I guess I'll do things right, and slowly migrate to 2.2.
> On Thu, Nov 3, 2011 at 10:34 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
>> What you could do is do a subversion checkout of the following directories
>> from
>> http://svn.osgeo.org/mapguide/branches/2.2/MgDev/Web/src/
>> - mapviewerphp
>> - viewerfiles
>> - stdicons
>> - any other directories you may have modified
>> And then trickle in your modifications. If anything goes wrong, you can
>> svn
>> revert back to a clean slate.
>> If your modifications haven't touched anything under mapviewerphp or
>> viewerfiles, you could probably do a wholesale replacement of your
>> existing
>> mapviewerphp and viewerfiles with the v2.2 copies (backing up the original
>> dirs in case things go wrong of course)
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Google-Chrome-AJAX-Viewer-tp6958956p6961485.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
