[mapguide-users] Incompatible column type
Dave Wilson dave.wilson at autodesk.com
Fri Nov 4 10:20:52 EDT 2011
Create a view of the table that doesn't contain that column. Modify your layer to point to the view. Using a view has been explained here several times.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of T.kiran kumar reddy
Sent: Friday, November 04, 2011 1:00 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Incompatible column type
hi
 I am using mapguide server 2011 and mapguide studio and database sql
server2008 r2. My data base table contain time stamp field (which i kept this for my replication purpose). when i go to view data it is showing An exception occurred in FDO component. RDBMS: Incompatible column type. If i removed that field it is coming. please suggest how can i rectify this problem. i need that column in my table.
Thanks and regards
T.kiran
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Incompatible-column-type-tp6961815p6961815.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
