[mapguide-users] Map scale decreases in Fusion
Iulia Tamas iulia_tamas30 at yahoo.com
Fri Nov 4 12:17:23 EDT 2011
Hello,
The map scale is keep decreasing every time I change the Map from the Map Menu in Fusion.
I have set the Initial View values to :
 <CenterX>3</CenterX>
 <CenterY>4</CenterY>
  <Scale>180</Scale>
This values are taken in consideration only when fusion first loads, and after this,  the scale value is decreasing every time I change the Map.
Does anybody know why this happens and what should I do to correct this?
Thank You,
Iulia
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111104/f6c1e1bb/attachment.html
