[mapguide-users] Another Fusion Question scalebar this time.
Berg, Leandros van den [FGSBV] L.vdBerg at fugro.nl
Tue Nov 8 09:40:40 EST 2011
Hi Adam,
Have a look at the Slate template
fusion\templates\mapguide\slate\index.html. You don't need to create a
new container for it, just add the Scalebar div to your Map div.
<div id="Map">
  <div id="Scalebar"></div>
</div>
There are two types of Scalebar widgets, Scalebar and ScalebarDual and
as you can see from my post here
http://osgeo-org.1803224.n2.nabble.com/Scalebar-TypeError-Fusion-Error-a
nd-NS-ERROR-DOM-INVALID-ACCESS-ERR-td6917184.html
I'm having trouble with the Scalebar widget as well. I do however get
the ScalebarDual widget to work properly by setting the type to
ScalebarDual.
I hoop this is of any help to you.
Leandros
