[mapguide-users] Re: MapGuide Maestro 4.0 RC1 now available
Jackie Ng jumpinjackie at gmail.com
Wed Nov 16 21:17:16 EST 2011
1) Remove button should've been enabled. This is probably a bug and you
should file a ticket on it.
2) The basemap switcher widget uses a hard-coded list of commerical layer
types. Google Maps v3 is not in the list, hence the widget's incompatibility
3) Fusion for quite some time could not display maps with tiled/dynamic
combinations of layers. The trunk version of Fusion finally implements
support for this, but if you intend to use trunk builds of Fusion in MGOS
2.2, be aware that some widgets have been updated to use APIs introduced
after 2.2 (eg. QuickPlot) and will not work in a 2.2 installation.
4) "MainMap" is the symbolic identifier for this particular map that may be
referenced by other widgets. This is probably another shortcoming of the
editor in that renaming the map ID should auto-update any widgets that are
referencing it. Probably should file a ticket on this as well.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MapGuide-Maestro-4-0-RC1-now-available-tp6974958p7002606.html
