[mapguide-users] Fdo2Fdo tool
Dave Wilson dave.wilson at autodesk.com
Thu Nov 17 10:32:56 EST 2011
I am not sure how to do the command line version. I'm guessing it's just supplying a list of parameters as shown in the gui.
However in order to work with any database you have to have local database connectivity on whatever machine you install Fdo2Fdo on. It does not need to be on the database server. You could try installing an oracle instantclient to get your connectivity. Use the GUI once you have your instantclient installed and test your connection. Once you get the GUI to work you could try the command line.
Regards,
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Iulia Tamas
Sent: Thursday, November 17, 2011 3:34 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Fdo2Fdo tool
Hello,
I recently started using the Fdo2Fdo tool to copy  .sdf files to Oracle and I'm facing some problems:
1)  I tried to use Fdo2Fdo from command line to copy the files to Oracle but without success. Could anybody give me an example (cmd commands) of how to do that ?
2)  I tried to use the tool installed on my local post with the existing database on the virtual machine, but unsuccessfully. Fdo2Fdo  has to be installed on the same machine as the Oracle Data Base?
I would really appreciate your answers!
Thank you,
Iulia
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111117/c32755e9/attachment.html
