[mapguide-users] Re: Fdo2Fdo tool
Zac Spitzer zac.spitzer at gmail.com
Thu Nov 17 21:15:12 EST 2011
Care to share your command line for other's who might be trying to
do this (of course edit out any sensitive info)?
On Fri, Nov 18, 2011 at 3:18 AM, Iulia Tamas <iulia_tamas30 at yahoo.com> wrote:
> Thank you very much for your answers! With your help, I have managed to set
> up the connection and copy .sdf to Oracle from command line
> Iulia
> ________________________________
> From: djonio <DJonio at miami-airport.com>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, November 17, 2011 5:44 PM
> Subject: [mapguide-users] Re: Fdo2Fdo tool
> As Dave notes you certainly require DB connectivity. I would recommend using
> the latest instantclient.
> This is how I go from Oracle TO sdf files...
> Put something like these 3 lines in a bat/cmd file ... obviously fix'em for
> your situation.
> c:
> cd \SDF_Conversions
> "C:\FDO2FDO\7_7\Release\F2fcmd.exe" CopyTask test_copy_mv0_4.xml
> The following are the contents of "test_copy_mv0_4.xml" shown above....
> <FdoCopyTask>
>   <SourceConnection>
>     <FdoProvider>King.Oracle.0.1.1</FdoProvider>
> <FdoConnectionString>Username=GISMIA;Password=;Service=MAPGUIDE;OracleSchema=GISMIA;</FdoConnectionString>
>   </SourceConnection>
>   <DestinationConnection>
>     <FdoProvider>OSGeo.SDF.3.2</FdoProvider>
> <FdoConnectionString>File=C:\SDF_Conversions\mv0_4_floorplan.sdf;</FdoConnectionString>
>   </DestinationConnection>
>   <ClassCopyDefinition>
>     <SourceClassName>KingOra:GISMIA~MV0_4~GEOMETRY</SourceClassName>
> <DestinationClassName>KingOra:GISMIA~MV0_4~GEOMETRY</DestinationClassName>
>     <CopyFilter></CopyFilter>
>     <PropertyCopyDefinition>
>       <SourcePropertyName>MVID</SourcePropertyName>
>       <DestinationPropertyName>MVID</DestinationPropertyName>
>     </PropertyCopyDefinition>
>       <SourcePropertyName>ID</SourcePropertyName>
>       <DestinationPropertyName>ID</DestinationPropertyName>
>       <SourcePropertyName>ALTKEY</SourcePropertyName>
>       <DestinationPropertyName>ALTKEY</DestinationPropertyName>
>       <SourcePropertyName>VALIDFLG</SourcePropertyName>
>       <DestinationPropertyName>VALIDFLG</DestinationPropertyName>
>       <SourcePropertyName>NAME</SourcePropertyName>
>       <DestinationPropertyName>NAME</DestinationPropertyName>
>       <SourcePropertyName>FLOOR</SourcePropertyName>
>       <DestinationPropertyName>FLOOR</DestinationPropertyName>
>       <SourcePropertyName>SRCNAME</SourcePropertyName>
>       <DestinationPropertyName>SRCNAME</DestinationPropertyName>
>       <SourcePropertyName>LAYER</SourcePropertyName>
>       <DestinationPropertyName>LAYER</DestinationPropertyName>
>       <SourcePropertyName>AREASQFT</SourcePropertyName>
>       <DestinationPropertyName>AREASQFT</DestinationPropertyName>
>       <SourcePropertyName>PERIMETERFT</SourcePropertyName>
>       <DestinationPropertyName>PERIMETERFT</DestinationPropertyName>
>       <SourcePropertyName>TXTCONTENTS</SourcePropertyName>
>       <DestinationPropertyName>TXTCONTENTS</DestinationPropertyName>
>       <SourcePropertyName>GEOMETRY</SourcePropertyName>
>       <DestinationPropertyName>GEOMETRY</DestinationPropertyName>
>   </ClassCopyDefinition>
>   <CopyTaskAttributes>
>     <ExecuteApplySchema>TRUE</ExecuteApplySchema>
>     <ApplySchemaXMLFile></ApplySchemaXMLFile>
>     <CreateSpatialContext>TRUE</CreateSpatialContext>
>     <SpatialContextXMLFile></SpatialContextXMLFile>
>     <MagicClassName>TRUE</MagicClassName>
>     <MagicDataTypes>TRUE</MagicDataTypes>
>     <DeleteDestinationData>TRUE</DeleteDestinationData>
>   </CopyTaskAttributes>
>   <CopyToSDFAttributes>
>     <SDF_CreateFileIfMissing>TRUE</SDF_CreateFileIfMissing>
>     <SDF_OverwriteFile>TRUE</SDF_OverwriteFile>
>   </CopyToSDFAttributes>
>   <CopyToOracleAttributes>
>     <Oracle_SRID></Oracle_SRID>
>   </CopyToOracleAttributes>
> </FdoCopyTask>
> .... this XML was produced from the GUI tool. I am way to lazy to write such
> stuff myself.
> r,
> dennis
> http://osgeo-org.1803224.n2.nabble.com/Fdo2Fdo-tool-tp7003610p7004527.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
