[mapguide-users] Re: Localized Search, Quick Plot, and Print widgets
Berg, Leandros van den [FGSBV] L.vdBerg at fugro.nl
Tue Nov 22 06:32:39 EST 2011
Hi Jackie,
Thanks for your reply. I'm confirming localization changes kick in when
the web server is restarted. This may be a very unwelcome thing to do
though when running multiple websites on the web server. I found that
just stopping and starting the default application pool MapGuideAppPool
does also do the trick. However, this won't work with IIS v5.0 because
it doesn't have application pools.
Kind regards,
Leandros
