[mapguide-users] Re: Upgrading MaestroAPI
Hans Milling hm at geograf.dk
Tue Nov 22 07:41:28 EST 2011
Hi Gunter
Last monday I began the conversion of an application from Maestro 2.x to 4.x
and I ran into lots of problems. I've been bombarding Jackie with questions
and I have this table of changes that is not complete but might help you on
the way. In the near future I can put a page on the OSGeo website with code
samples etc. But for now this may be able to help you and others.
I need to say that I am not done and therefor the code cannot compile or run
and none of the findings in this table has been confirmed to be correct. But
most af them should be right.
v2.x 	v4.x
          IServerConnection con = new HttpServerConnection(host, sessionid,
"en", true);
          ConnectionProviderRegistry.CreateConnection("Maestro.Http", "Url="
+ host +
          ";SessionId=" + sessionid +
";Locale=en;AllowUntestedVersion=true");
          RuntimeMap map = con.GetRuntimeMap(mapid);
          IMappingService mapSvc =
(IMappingService)con.GetService((int)ServiceType.Mapping);
          RuntimeMap map = mapSvc.OpenMap(mapid);
          new IMapDefinition()
          ObjectFactory.CreateMapDefinition(con, map.Name);
          RuntimeMap map = new RuntimeMap(mdef);
          IMapDefinition mapDef =
(IMapDefinition)con.ResourceService.GetResource(mapid);
          RuntimeMap map = mapSvc.CreateMap(mapDef);
          IWebLayout layout = con.GetWebLayout(webLayout);
          IWebLayout layout =
(IWebLayout)con.ResourceService.GetResource(webLayout);
          MapDefinition layer = con.GetMapDefinition(mapDefId);
          IMapDefinition layout =
(IMapDefinition)con.ResourceService.GetResource(mapDefId);
          MapDefinition.BaseMapDefinition
          IMapDefinition.
          for (int i = 0; i < mdef.BaseMap.FiniteDisplayScale.Count; i++)
          foreach (double d in baseMap.FiniteDisplayScale)
          RuntimeMapLayer.Geometry
          RuntimeMapLayer.GeometryPropertyName
          RuntimeMapLayer.Guid
          RuntimeMapLayer.LayerDefinitionID
          LayerDefinition ldef = con.GetLayerDefinition(rl.ResourceId);
          ILayerDefinition ldef =
(ILayerDefinition)con.ResourceService.GetResource(rl.LayerDefinitionID);
          FeatureSource fs = con.GetFeatureSource(vldef.ResourceId);
          IFeatureSource fs = ObjectFactory.CreateFeatureSource(con,
vldef.ResourceId);
          RuntimeMap.LayerGroups
          RuntimeMap.Groups
          map.Layers.RemoveAt(0);
          Add:
          using System.Linq;
          To make this work.
          con.SaveResourceAs(mdef, rtmDef);
          con.ResourceService.SaveResourceAs(mdef, rtmDef);
          ldef.Item as VectorLayerDefinitionType
          ldef.SubLayer;
          FeatureSetReader rd = layer.Query(filter, new string[] {
layer.Geometry })
          IReader rd =
map.CurrentConnection.FeatureService.QueryFeatureSource(layer.FeatureSourceID,
          layer.QualifiedClassName, new string[] {
layer.GeometryPropertyName })
          VectorScaleRangeType.Items
          IVectorScaleRange.PointStyle
          IVectorScaleRange.LineStyle
          IVectorScaleRange.AreaStyle
          VectorScaleRange.MinScaleSpecified/MaxScaleSpecified
          IVectorScaleRange.MinScale.HasValue/.MaxScale.HasValue
          PointTypeStyleType
          IPointVectorStyle
          LineTypeStyleType
          ILineVectorStyle
          AreaTypeStyleType
          IAreaVectorStyle
          LineRuleType
          ILineRule
          PointRuleType.Item
          IPointRule.PointSymbolization2D
          LineRuleType.Item
          ILineRule.Stroke
          AreaRuleType.Item
          IAreaRule.AreaSymbolization2D
          AreaTypeStyleType.AreaRule
          IAreaVectorStyle.Rules
          GridLayerDefinitionType
          IRasterLayerDefinition
          LayerDefinition.Item
          ILayerDefinition
          LineTypeStyle.Items
         ILineRule.Strokes
          ServerConnectionI.GetLegendImage
            IMappingServicea.RenderMapLegend
          ServerConnectionI.DescribeFeatureSource
            IServerConnection.FeatureService.DescribeFeatureSource
          FeatureSourceReader.Read()
            IReader.ReadNext()
          FeatureSourceReader.Row.IsValueNull(column)
            IReader.IsNull(column)
          foreach (FeatureSetColumn fsc in fsr.Columns)
            for (int i=0; i<fsr.FieldCount; i++)
          FeatureSetReader.Columns.Length
            IReader.FieldCount
          FeatureSetReader.Columns[i].Type
            IReader.GetFieldType(i)
          FeatureSourceDescription.FeatureSourceSchema
            FeatureSchema
          RuntimeMapLayer.NeedRefresh
            RuntimeMapLayer.NeedsRefresh (to get)
RuntimeMapLayer.ForceRefresh() (to set)
          RuntimeMapLayer.ResourceID
          RuntimeMap.Extents
            RuntimeMap.DataExtent
          ServerConnectionI.HasFolder
            con.ResourceService.ResourceExists(folderpath)
            Make sure that folderpath ends with '/' to indicate it's a
folder
          ServerConnectionI.CreateFolder
            con.ResourceService.SetResourceXmlData(folderpath, null)
          RuntimeMapLayer.ResourceId
          map.FiniteScales
            IMapDefinition mdef =
(IMapDefinition)map.CurrentConnection.ResourceService.GetResource(map.MapDefinition);
            IBaseMapDefinition bm = mdef.BaseMap;
            bm.FiniteDisplayScale.ToArray();
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Upgrading-MaestroAPI-tp7019938p7020272.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111122/87e9d6bf/attachment.html
