[mapguide-users] MGOS 2.2 crash with WMS
Andreas Morf a.morf at fkl.ch
Tue Nov 22 08:59:02 EST 2011
Hi Zac
Can you provide a hint where to look for these wms improvements in svn?
Thx, Andreas
> -----Ursprüngliche Nachricht-----
> Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] Im Auftrag von Zac Spitzer
> Gesendet: Mittwoch, 16. November 2011 01:55
> An: MapGuide Users Mail List
> Betreff: Re: [mapguide-users] MGOS 2.2 crash with WMS
> there has been a lot of work recently by AutoDesk on the WMS
> side of things, which probably has fixed this problem. That code
> hasn't been formally released yet, but it's available in svn.
> Are the WMS services public? Ideally if you could provide a MGP sample
> Does the error occur with both fusion (flexible) and the ajax (classic)
> viewer
> On Fri, Nov 11, 2011 at 9:52 PM, Sal <opc_1 at hotmail.it> wrote:
> > Hi all,
> > I migrated my application from MGOS 2.0.2 to MGOS 2.2 because I need
> to get
> > raster images from 2 different WMS services.
> > I installed MGOS 2.2 on CentOS  5.3 server, but using my application
> I get
> > random crash of MGOS. I analized error.log but, strangely, there
> isn't any
> > error about crash.
> > After many test of my application I found that map with 2 WMS or also
> just
> > one WMS causes a crash after some selecting/deselecting cycles of all
> > layers. The same map without WMS works fine. In the WMS request I
> must
> > specify "version=1.1.0" for the first WMS service and "version=1.1.1"
> for
> > the second WMS service.
> > Part of the layers get data from MySql DBMS 5.1, the other ones get
> data
> > from shape files (all together there are 12 layers).
> > The coordinate system of map is Lat/Lon WGS 84. Also WMS maps are in
> > EPSG:4326.
> > About configuration:
> > CentOS 5.3
> > MGOS 2.2
> > MGOS 2.2 bundle version of Fusion and Apache
> > FDO 3.5
> > DB MySql 5.1
> > I attached to this post the error.log and trace.log.
> > Can anyone help me?
> > Thanks
> > Salvatore
> > http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Trace.log
> Trace.log
> > http://osgeo-org.1803224.n2.nabble.com/file/n6985005/Error.log
> Error.log
> > View this message in context: http://osgeo-
> org.1803224.n2.nabble.com/MGOS-2-2-crash-with-WMS-
> tp6985005p6985005.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
