[mapguide-users] RE: Points from Sql/ODBC data source not showing
GIS4U johnniegis at gmail.com
Wed Nov 23 19:43:49 EST 2011
Did you end up getting it working?
If not, can you provide some info on:
   1. How many points are you talking about?  Given it is a test dataset I
   am assuming it is not really large.
   2. Can you view the attributes in the Feature Source? If you preview, do
   they display?
   3. Have you tried resetting the schema?
   4. Often times if you can see the feature source but not the layer then
   physically deleting the layer and recreating will help.
   5. Have you run MG in debug mode?  Any errors show up?
On Wed, Nov 23, 2011 at 1:29 PM, soudemans <soudemans at ruekert-mielke.com>wrote:
> I guess it is time to cut my losses, so I pondered the next dilemma, if I
> am
> going to put the data in a spatial data base, which will have to be ArcSDE,
> since the client uses MS SQL Server 2005, then how would I add a record and
> point data from the map's interface.  How indeed?  I checked with our
> resident Arc-spert who gave me one of those "you've got to be kidding
> looks"
> and then recommended "Don't".  This does not mean that it is impossible;
> instead it would be a horrendous work around.  I think I mentioned before
> that this should not be rocket science, so I am baffled by the fact that I
> am now considering things like storing the data in XML data sources, or
> finding some other work-around.  It is a good thing I am going home in an
> hour to prepare myself for the annual tradition of consuming turkey and
> beer.  But if any-one has experience with this and would be willing to
> share
> I would be much obliged to read whatever suggestions you may come up with.
> In the meantime Happy Thanksgiving to all that celebrate turkey day.
> http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7026225.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111123/5ff5d2d5/attachment.html
