[mapguide-users] RE: Points from Sql/ODBC data source not showing
Andrew DeMerchant andrew.demerchant at gemtec.ca
Mon Nov 28 16:16:42 EST 2011
Can we see a screen cap of your preview?
On 11/11/28 5:06 PM, soudemans wrote:
> andrewd wrote
>> You should be able to preview it using Maestro. The attached screen cap
>> shows what an ODBC data source looks like when previewed. To get the
>> map, you need to click "view feature" for a class with geometry.
>> Andrew
> Thanks Andrew for your suggestion,
> I should be able to preview it in MapGuide Studio as well, but like I said I
> get nothing.  Do you have reasons to believe that this is some kind of
> compatibility issue between MapGuide OSGeo and MapGuide Studio?  If it is
> let me know what those reasons are.  Unfortunately, the client I am doing
> this for is using MapGuide Studio, and before I want to suggest that they
> install MAESTRO I want to make sure it can't be done any other way.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Points-from-Sql-ODBC-data-source-not-showing-tp7021115p7040380.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025  /  toll-free: 1.877.243.6832
fax: 506.453.9470
Skipped content of type multipart/related
