[mapguide-users] Join between an Oracle spatial table and a view
Iulia Tamas iulia_tamas30 at yahoo.com
Tue Nov 29 07:25:00 EST 2011
Thanks for the info.. I've created a new view in Oracle, I've added the entry in user_sdo_geom_metadata (using the fdo2fdo tool) and everything works fine.
I would like to add this entry manually (not using the tool) but the problem is that I don't know how the values in the DIMINFO column of the user_sdo_geom_metadata table are calculated...
For ex. : MDSYS.SDO_DIM_ELEMENT(MDSYS.SDO_DIM_ELEMENT(X,-25.2145,73.0093,0.05),MDSYS.SDO_DIM_ELEMENT(Y,-21.2004,74.7297,0.05))
And also if the SRID 8307 is the corresponding value of the LL84 (WGS84) Coordinate System, which is the correpsonding SRID value for the XY-M (Arbitrary X-Y Coordinates (Meters)) Coordinate System?
Thank You,
Iulia
 From: "Jonio, Dennis (Aviation)" <DJonio at miami-airport.com>
To: Iulia Tamas <iulia_tamas30 at yahoo.com>; MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Wednesday, November 23, 2011 4:00 PM
Subject: RE: [mapguide-users] Join between an Oracle spatial table and a view
Iulia,
I would recommend:
1)      Create a “normal” Oracle view w/your join
2)      Add the entry for it in user_sdo_geom_metadata. (No need for an index.)
3)      Create a layer for the view …
Does all appear normal and as expected?
All that I am suggesting here is to gradually add complexity. No need to boil the ocean from the get-go. You can delete/remove this stuff later.  But maybe you have already done these things.. in which case I am no help.
r,
dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111129/ecfeb129/attachment.html
