[mapguide-users] Re: Problems add LayerDefinition to MapDefinition (MaestroAPI 4.0)
Jackie Ng jumpinjackie at gmail.com
Tue Nov 29 07:42:09 EST 2011
When you add a layer to the Map Definition, if it is the first layer to be
added, Maestro tries to be smart and grabs the extents of that layer and
sets the extents of the Map Definition to match.
This obviously naively assumes the first layer you add has no issues and can
be queried for extents.
I think what we can do is expose a boolean property which will determine
whether this behaviour will occur or not. The default value will be false,
but will be set to true by the Map Definition Editor in Maestro.
If you think this is an acceptable solution, make a ticket for this on trac.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problems-add-LayerDefinition-to-MapDefinition-MaestroAPI-4-0-tp7042582p7042692.html
