[mapguide-users] Re: Basic Viewer layout
Zac Spitzer zac.spitzer at gmail.com
Fri Oct 7 22:46:28 EDT 2011
are u using firebug to investigate?
On Sat, Oct 8, 2011 at 5:00 AM, frosty1_4me <kbowman at cityofgp.com> wrote:
> There is definitely something else at work here.  If I change the
> toolbarheight to say 50px as Gord has pointed out to resize the toolbar
> area, the size of the toolbar does indeed get larger.  However, the
> background image stays the same.  That background image is 34px in height
> so
> it should be wider when I change that toolbarheight yet it isn't.
> It seems to be defined by a table row height and the only place I found
> that
> was in the InitToolbar() function on line 212 of the toolbar.templ file but
> changing that height also does not increase the background height.
> If I set the background image to repeat vertically, it will repeat and fill
> the 50px height that is set against the toolbarheight, but the actual
> height
> of the image displays the same 26px image twice in the 50px height toolbar
> with a border around the image.   That indicates to me that the background
> height is being defined somewhere else.
> http://osgeo-org.1803224.n2.nabble.com/Basic-Viewer-layout-tp6860116p6870438.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111008/98db3afc/attachment.html
