[mapguide-users] Re: Coordinate system override for SQL Server 2008
Ward Kilby wkilby at telus.net
Sat Oct 8 13:47:58 EDT 2011
I did use the CS override but being new to using SQL Server with MGOS (used
MS Access before) I may be doing something wrong. When I set up a feature
source connection to Sql S it finds the datastore (my data base of many
imported shapefiles). But when I try to do a CS override I get strange
results. I can set source as Default and pick the appropriate Target system.
But if I say load defaults it finds Default plus data from each record in
one of the database files and not the actual database files. I have been
adjusting the Default and Target values but nothing seems to work. When I do
a batch load of all the shapefiles into MGOS' repository everything works
great in any desired projection. So I suspect it is my ignorance of using
SQL Server. Suggestions.
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Coordinate-system-override-for-SQL-Server-2008-tp6870641p6872932.html
