[mapguide-users] Digitize Circle and get xml selection in Fusion
Michael Adair madair at dmsolutions.ca
Wed Oct 19 09:05:46 EDT 2011
For making a circle handler, just copy the Rectangle handler (which uses
a Regular Polygon handler) and increase the number of sides to something
like 40.
For the selections, register a Fusion.Event.MAP_SELECTION_ON event
listener on the map object and then you can use the map.getSelection()
method passing in a callback function that you can use to process the
results.
Mike
On 19/10/2011 3:37 AM, Iulia Tamas wrote:
> Hello
> I have the 2 following problems with Fusion (MapGuide 2.2):
> 1) I don't know how could I digitize a circle because in
> MapguideViewerApi.js I have found only :  DigitizePoint / DigitizeLine
> / DigitizeLineString / DigitizeRectangle / DigitizePolygon
> 2) How can I get the xml selection from the Map. I know that in Ajax
> we have GetSelectionXML() but I couldn't find a similar function in Fusion
> Thank You,
> Iulia
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111019/c41f724c/attachment.html
