[mapguide-users] plot to dwf comes out differently than current map view
tmblackflag steve.calpoly at gmail.com
Thu Oct 27 18:56:03 EDT 2011
Has anyone experience this? I am plotting the current view to a 17x11 paper
size and the DWF always results in data at slightly more scale (meaning
extra white space around all polygons).
I am using this code to plot.
            try
                // Initialize the web-tier and connect to the Site using
                // the session identifier stored in ASPX session state.
                InitializeWebTier();
                MgUserInformation userInfo = new
MgUserInformation(mgSessionId);
                MgSiteConnection siteConnection = new MgSiteConnection();
                siteConnection.Open(userInfo);
                // Create an instance of ResourceService and use that to
open the
                // current map instance stored in session state.
                MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
                MgMap map = new MgMap();
                map.Open(resourceService, mapName);
                // Now create an instance of MappingService and use it to
plot the
                // current view of the map.
                MgDwfVersion dwfVersion = new MgDwfVersion("6.01", "1.2");
                MgPlotSpecification plotSpec = new MgPlotSpecification(17,
11, MgPageUnitsType.Inches, 0f, 0f, 0f, 0f); //17x11
                plotSpec.SetMargins(0.25f, 0.25f, 0.25f, 0.25f);
                MgMappingService mappingService =
siteConnection.CreateService(MgServiceType.MappingService) as
MgMappingService;
                MgLayout layout = null;
                double scale = map.GetViewScale();
                MgByteReader byteReader = null;
                if (scale <= 0)
                    byteReader = mappingService.GeneratePlot(map, plotSpec,
layout, dwfVersion);
                else
                    MgCoordinate mapCenter =
map.GetViewCenter().GetCoordinate();
                    byteReader = mappingService.GeneratePlot(map, mapCenter,
scale, plotSpec, layout, dwfVersion);
                // Now output the resulting DWF.
                OutputReaderContent(Response, byteReader);
            catch (MgException mge)
                String result = mge.GetExceptionMessage() + "<br><br>" +
mge.GetDetails();
                Response.ContentType = "text/html";
                Response.Write(result);
View this message in context: http://osgeo-org.1803224.n2.nabble.com/plot-to-dwf-comes-out-differently-than-current-map-view-tp6938331p6938331.html
