[mapguide-users] Re: Scale Stops Selection
GIS4U johnniegis at gmail.com
Thu Sep 8 13:03:19 EDT 2011
Hi Gordon,
Don't use the Fusion layouts much I'm afraid so I doubt I'll be of much
help.  Have you tried it from the Basic layout just to confirm whether it is
MG itself or viewer?
Jonathon
On Thu, Sep 8, 2011 at 9:53 AM, GordonL
<gordon.luckett at arrowgeomatics.com>wrote:
> Thanks Jonathan,  actually to follow up - it's a single layer "buildings" -
> available at all scales.
> If you look at the Selection widget there is attribute data there - meaning
> it is selecting the object - its just the overlay selection highlight that
> is missing (blue).
> The only other pertinent issue is that I am using the *
> &theme=Library://Map/Marriott.MapDefinition* for the Flexible Web Layout
> URL
> Parameter.  I wonder if the overview map in the default layout is the
> issue...
> gordon
> http://osgeo-org.1803224.n2.nabble.com/Scale-Stops-Selection-tp6772519p6772689.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110908/d38048d3/attachment.html
