[mapguide-users] limitation in the number of files
Jason Birch jason at jasonbirch.com
Mon Sep 12 01:01:55 EDT 2011
Agreed.
I think the maximum file size for an .mgp is somewhere around 2GB. no?
And if you're loading them via the web API (rather than the admin interface)
you're likely to run into timeouts well before that.
Jason
On 10 September 2011 20:28, Zac Spitzer wrote:
> you probably will have issues with performance, etc
> before you hit any limits.
> A mapguide package is simply a zip file containing all the resources
> with a manifest which is a basically loading scripting to push all those
> resources into the mapguide repository.
> z
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110911/1e0e571f/attachment.html
