[mapguide-users] Replace sheboygan with some other package!!!!!!!!!!!!
Zac Spitzer zac.spitzer at gmail.com
Mon Sep 26 04:00:08 EDT 2011
what do you think?
*headdesk*
On Mon, Sep 26, 2011 at 5:54 PM, Nishi Pachoree <nishipachoree9 at gmail.com>wrote:
> Hi,
> I have replaced the sheboygan package with the new package using
> mapadmin...now when i run the ajaxviewersample.aspx page it displays the
> same sheboygan map...i guess the reason is the path
> String
> webLayout = "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
> in the code ,do i have to change this path on this page as well as
> everywhere else ,coz the map is being displayed is of sheboygan only
> irrespectice of replacing the package.
> On Mon, Sep 26, 2011 at 1:17 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>> you know how to load the sheboygan package? both mapadmin and maestro
>> allow
>> you to import and export packages
>> z
>> On Mon, Sep 26, 2011 at 5:44 PM, Nishi Pachoree <nishipachoree9 at gmail.com
>> > wrote:
>>> sry but i didnt get you :(
>>> On Mon, Sep 26, 2011 at 1:13 PM, Zac Spitzer <zac.spitzer at gmail.com>wrote:
>>>> the same way you load a package also allows you to export a package?
>>>>   On Mon, Sep 26, 2011 at 5:41 PM, Nishi Pachoree <
>>>> nishipachoree9 at gmail.com> wrote:
>>>>>   Hi,
>>>>> I have installed mapguide server and mapguide webserver extension with
>>>>> dotnetviewersample,and sheboygan package.Now i want to replace the sheboygan
>>>>> package with my own package so  that i can display a different map ?Can
>>>>> anyone advice me where exactly and what changes should i make or what steps
>>>>> should i follow to accomplish my goal.
>>>>> Thanks and Regards
>>>>> Nishi
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> mapguide-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> Zac Spitzer
>>>> Solution Architect / Director
>>>> Ennoble Consultancy Australia
>>>> http://www.ennoble.com.au
>>>> http://zacster.blogspot.com
>>>> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110926/a8c0666c/attachment.html
