[mapguide-users] Expired Sessions in Error Log
Zac Spitzer zac.spitzer at gmail.com
Mon Apr 23 08:59:45 EDT 2012
I agree such standard errors don't require stack traces in production,
can you file a bug in trac?
http://trac.osgeo.org/mapguide/
there are a few other common errors which could also
abbreviated
On Mon, Apr 23, 2012 at 9:54 PM, Nickthetemp <nickthetemp at gmail.com> wrote:
> Hello All.
> I am wondering if anyone knows a way to avoid writing expired sessions to
> the error log?
> I am trying to do some debugging and it is very annoying trying to sift
> through the thousands of expired sessions in the log. I emptied the error
> log a week ago and it is now 125000 lines long :(
> here is an example (same error each time from same ip):
> Error: Session has expired or is invalid. Please log in again.
>  StackTrace:
>  - MgSiteServiceHandler.ProcessOperation() line 83 file
> d:\build\mge2012\build_50.1\ent\os\server\src\services\site\SiteServiceHandler.cpp
>  - MgOpAuthenticate.Execute() line 116 file
> d:\build\mge2012\build_50.1\ent\os\server\src\services\site\OpAuthenticate.cpp
>  - MgServerSiteService.Authenticate() line 709 file
> d:\build\mge2012\build_50.1\ent\os\server\src\services\site\ServerSiteService.cpp
>  - MgSecurityManager.Authenticate() line 224 file
> d:\Build\MGE2012\BUILD_50.1\Ent\OS\Server\src\Common\Manager\SecurityManager.cpp
>  - MgSessionCache.GetSessionInfo() line 175 file
> d:\Build\MGE2012\BUILD_50.1\Ent\OS\Server\src\Common\Manager\SessionCache.cpp
> <2012-04-23T08:45:25>   6320    Ajax Viewer     66.249.71.102
> <2012-04-23T08:45:31>   6920    Ajax Viewer     66.249.71.102
> <2012-04-23T08:45:35>   888     Ajax Viewer     66.249.71.102
> <2012-04-23T08:46:49>   7460    Ajax Viewer     66.249.71.102
> <2012-04-23T08:46:54>   888     Ajax Viewer     66.249.71.102
> <2012-04-23T08:46:59>   7112    Ajax Viewer     66.249.71.102
> As you can see they are getting wrote to the error log several times/min for
> the same expired session.
> I am using Autodesk Infrastructure Map server 2012.
> Thanks in advance for your help.
> Nick
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Expired-Sessions-in-Error-Log-tp4909927p4909927.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
