[mapguide-users] Re: MapGuide 2.2 does not login as Administrator
Hans Milling hm at geograf.dk
Fri Apr 27 06:30:25 EDT 2012
Perhaps PHP is not working?
Try from a browser to access:
http://localhost/mapguide/mapagent/mapagent.fcgi
Change the url to match your MapGuide installation.
If everthing works you should get a login box where you can enter the
username and password. If this is accepted you get a white page. if not you
will get an error of some kind.
Best Regards Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-2-does-not-login-as-Administrator-tp4933468p4933520.html
