[mapguide-users] Problem with SQL connection
Jackie Ng jumpinjackie at gmail.com
Mon Aug 20 19:42:37 PDT 2012
In SQL Server, there's 2 ways to authenticate when connecting
 1. Using SQL Server logins
 2. Using Windows user accounts
Connecting without specifying a username/password in the UI will instruct
the SQL Server FDO provider to use Windows Authentication using the
username/password of the windows user account that the MapGuide Server
process is running under.
If you don't connect to SQL Server with Windows Authentication then it
doesn't really concern you.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-SQL-connection-tp4996520p4996532.html
