[mapguide-users] multiple coordinate systems SQL spatial?
Zac Spitzer zac.spitzer at gmail.com
Wed Feb 29 22:47:40 EST 2012
which db are you using?
any reason you aren't just storing the geometries using the correct
SRS to start with?
z
On Thu, Mar 1, 2012 at 2:43 PM, Jamo <adam.jamison at portbris.com.au> wrote:
> Curious to know if it is possible to specify which cordinate system certain
> features sets are in at the datasource level in mapguide?
> I notice its possible to add coordinate system overrides, any chance someone
> can point me in the right direction or give me a quick run through?
> I've been specifying everything for my project as geometry with a SRS of 0
> which is EPSG:28356, then I have a few geography features where the SRS is
> 4326.
> If you require further information please advise :)
> View this message in context: http://osgeo-org.1560.n6.nabble.com/multiple-coordinate-systems-SQL-spatial-tp4533662p4533662.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
