[mapguide-users] MapGuide 2.2 GDAL Raster Provider - a little help finding some files
Zac Spitzer zac.spitzer at gmail.com
Thu Jan 5 19:11:53 EST 2012
Trevor going to be looking into a GDAL 1.9 upgrade for FDO
http://osgeo-org.1803224.n2.nabble.com/Create-a-branch-for-GDAL-1-9-upgrade-td7152167.html
z
On Thu, Jan 5, 2012 at 6:43 AM, Matt McLean <mmclean at cgis.com> wrote:
> Thanks for the response!  Actually, I just got a response from Tamas who had
> an old copy of the file that I was looking for.  I'm going to give it a go
> before resorting to trying with a newer, or custom build of GDAL.  Good to
> know that you've had good luck with your own builds if I need to go that
> route.
> Thanks again.
> On Wed, Jan 4, 2012 at 1:25 PM, Gabriele Monfardini <gabrimonfa at gmail.com>
> wrote:
>> > Problem is that the file is no longer available on Tamas' site.  Does
>> > anyone
>> > have a copy of this file kicking around that they could send my way?
>> >  Alternatively, can anyone confirm if a newer build would work - and be
>> > stable?
>> I'm on Linux and for some reasons I have to compile gdal myself.
>> I've compiled and used (in production sites) version 1.6.0, version
>> 1.6.3 (last release in 1.6 branch if I remember correctly) and version
>> 1.7.2, without particular problems on tiff and png rasters (even if
>> some care is required preparing the files, and I strongly suggest
>> testing the files with gdalinfo prior to deploy it).
>> I've also tried version 1.8 from SVN some times ago and had some
>> problems with mapguide. At the time I had not enough time to
>> investigate the reason, also because version 1.7 appered to run well.
>> I've compiled it passing the parameter (--with-thread), that for
>> versions below 1.8 is not the default, in order to have multithread
>> support.
>> So probably a correctly compiled gdal 1.6 or 1.7 for windows is going to
>> work.
>> Regards,
>> Gabriele Monfardini
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
