[mapguide-users] Modify Map with base layers before load?
David Hequet david.hequet at free.fr
Tue Jan 10 06:44:37 EST 2012
Actually i'm modifying my map before load by copy in session repo before
loading the weblayout
the steps ares:
- copy wl in session
- copy mapdefinition in repo
- add layer to mapdef
- update wl map resid
I need to use base layer for some performance issue, but copying the map to
the session change the map name and mapguide create a new tile folder.
Do you think there is a possibility to avoid this?
Thank you
David
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Modify-Map-with-base-layers-before-load-tp7171738p7171738.html
