AW: [mapguide-users] Get symbol not to zoom
David Das Neves neves at systemtechnik.net
Wed Jan 11 03:29:11 EST 2012
Ah thx - it worked. Values of 250 helped here.
Sometimes it´s just good to let someone other to look at the code.
Greetings
David
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von mika at digikartta.net
Gesendet: Mittwoch, 11. Januar 2012 08:51
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] Get symbol not to zoom
 Hi David,
 maybe you just have to scale it bigger?
 Add like
               <ScaleX>10</ScaleX>
               <ScaleY>10</ScaleY>
 before        <SizeContext>MappingUnits</SizeContext>
 and adjust the values. How much is for example 10 mapping units? Not  much?
 - mika -
 On Wed, 11 Jan 2012 07:02:12 +0000, David Das Neves  <neves at systemtechnik.net> wrote:
> Hello all,
> I have a little problem and do not find any way to solve it. So
> normally when u set a Feature style for an layer with points, you can
> define the size context the size units.
> By this parameters it is possible to give the symbols static sizes so
> that they don't get smaller when you zoom in on the mapview.
> Now I am using a _SimpleSymbolDefinition_ to specify my own type of a
> symbol. It looks like this which is an arrow:
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
