[mapguide-users] Re: 64-bit woes
Hans Milling hm at geograf.dk
Wed Jan 11 10:01:37 EST 2012
I think the problems relate to another dll (third party perhaps) that is 32
bit. If the DLL is compiled as AnyCPU it will launch as a 32 bit on a 32 bit
machine and if launched from a 64 bit process on a 64 bit machine it will
run as 64 bit. Then loading the 32 bit DLL that it depends on will fail on
the 64 bit machine.
You can perhaps use dependency walker to detect the DLL unable to be loaded
and replace it by a 64 bit version? Dependency walker will also tell the
bitness of each dll (x86 or x64). You should be able to see a mismatch
somewhere then.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/64-bit-woes-tp7122196p7176484.html
