[mapguide-users] Re: 64-bit woes
Jonathan Rizzo jrizzo at Langan.com
Wed Jan 11 13:20:25 EST 2012
This is what I had done originally (and others as well, from the looks of things).  When I used the 32 bit dll's, the application would compile, but the web site displayed the "wrong format" exception when I tried to debug the web site.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Crispin_at_Linknode
Sent: Wednesday, January 11, 2012 12:42 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: 64-bit woes
There is a slightly better way to achieve this (assuming .NET application on
x64 machine).
On a x64 machine install the 64-bit version of MapGuide.
This will install the 64-bit server and configure the 64-bt web-tier.
Also download and extract the 32-bit versions of all the web-tier DLLs for the next step.
In your application in Visual Studio use the 32-bit references (and copy all the folders from the 32-bit ajaxviewer\bin folder to your project\bin folder).
Configure your VS project to run under an IIS virtual directory.  Add a new 32-bit compatible app-pool to IIS to ensure that you are 32-bit compatible and set your application to use that app pool.
You application can then use the standard webconfig.ini to initialise but will run the web-tier in 32-bit mode allowing you to debug but communicate with the 64-bit server and services for native compatibility.
The only problem I have left is that I have applications that also require an Oracle client and I cannot get a 32-bit Ora client to run on x64 so I am stuck with the "incorrect format" problem.
Could someone advise if this is due to the web-tier DLLs being compiled in specific x86 and x64 versions - if the web-tier were compiled in "any CPU"
would this solve the problem generically?
linknode.co.uk
View this message in context: http://osgeo-org.1803224.n2.nabble.com/64-bit-woes-tp7122196p7177079.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
This electronic transmission may contain confidential, proprietary or privileged information. No confidentiality or privilege is intended to be waived or lost by erroneous transmission of this message. If you receive this message in error, please notify the sender immediately by return email and delete this message from your system. Disclosure, use, distribution or copying of this message, any attachments thereto or their contents is strictly prohibited.
