[mapguide-users] Different colors for one selection
GIS4U johnniegis at gmail.com
Thu Jan 12 19:14:10 EST 2012
Perhaps come at it from a different angle...
What if you filtered the layer in the Session based on values (cycle
through selected objects in code and group them based on ??) and then
displayed those polygons in the color of your choice by writing a session
layer/layers...not a 'selection' per se but perhaps the result may be what
you need
On Wed, Jan 11, 2012 at 5:21 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> I'm pretty sure selection only supports one color
> the options are to either render a custom layer to show your selections
> via mapguide, or render your selections using vector layer support in
> openlayers (if you are using fusion)
> both options require would require some non trivial development
> On Thu, Jan 12, 2012 at 1:54 AM, David Das Neves
> <neves at systemtechnik.net> wrote:
> > Hey guys,
> > I have a little question which the experts of you may answer easily.
> > Is it possible to show selected features in different colors in one view:
> > e.g. 5 selected features in the color red other five in blue and so on –
> on
> > the same view in the ajax viewer?
> > The only thing I found was the modification of the color in the
> > ajaxmappane.templ which works global.
> > And by knowing only this I think that my “multi-coloring” is not
> possible.
> > Greetings
> > David das Neves
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120112/61148c85/attachment.html
