[mapguide-users] Re: DLL Errors on a 64 Bit OSGeo Implementation
Hans Milling hm at geograf.dk
Fri Jan 20 05:20:19 EST 2012
Signing the DLL files are important if you use Local Native connections.
If you need help, this application will sign the dll files for you:
http://svn.osgeo.org/mapguide/trunk/Tools/Maestro/SignMapGuideApi/
Compile the code (console application) put the exe in a directory with the
dll files and the maestroapi.key file and run it.
Best regards Hans Milling...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/DLL-Errors-on-a-64-Bit-OSGeo-Implementation-tp7205633p7206983.html
