[mapguide-users] Re: Enhanced Stylization - <repeat> value
Traian Stanev traian.stanev at autodesk.com
Fri Jan 20 10:41:01 EST 2012
To be precise, if repeat is set to zero or a negative number, the symbol will only be placed at the start and/or end offset positions. I assume that removing the repeat element just sets it to zero which has the desired effect.
Here is some extra information from Walt for about what happens when repeat <= 0:
For non-positive Repeat values the VertexControl option is ignored, and the following rules apply to the StartOffset and EndOffset parameters:
*	if the StartOffset is specified (>=0) then a symbol is drawn at the start offset location
*	if the EndOffset is specified (>=0) then a symbol is drawn at the end offset location
*	if the StartOffset and EndOffset are both specified but their sum is greater than the polyline length (the EndOffset offset location comes before the StartOffset location) then no symbols are drawn
*	if the StartOffset and EndOffset are both unspecified (< 0) then no symbols are drawn
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of GordonL
> Sent: Thursday, January 19, 2012 9:39 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: Enhanced Stylization - <repeat> value
> Ok, I figured it out.  If the repeat is completely missing and one of the begin or
> end tags are missing, it automatically puts the symbol at the associated end.  For
> example,
>  <LineUsage>
>     <AngleControl>'FromAngle'</AngleControl>
>     <VertexControl>'OverlapNoWrap'</VertexControl>
>     <Angle>0</Angle>
>     <StartOffset>0</StartOffset>
>   </LineUsage>
> Puts a symbol at the beginning of the line - easy peasy.
> View this message in context: http://osgeo-
> org.1803224.n2.nabble.com/Enhanced-Stylization-repeat-value-
> tp7205972p7206188.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
