[mapguide-users] AW: Showing point in map
David Das Neves neves at systemtechnik.net
Tue Jan 24 07:11:05 EST 2012
Ah thank you for the hint.
After the mgServer.exe was holding about 1,5GB and crashed I had to restart it.
And then - after I built in the result value to see if the point is created correctly it gave me back that it worked.
And after a look on the map - it worked really! ;)
Greetings
David
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Ivan Milicevic
Gesendet: Dienstag, 24. Januar 2012 11:04
An: MapGuide Users Mail List
Betreff: [mapguide-users] RE: Showing point in map
And please take a look at: http://trac.osgeo.org/mapguide/ticket/649
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org> [mailto:mapguide-users-bounces at lists.osgeo.org]<mailto:[mailto:mapguide-users-bounces at lists.osgeo.org]> On Behalf Of David Das Neves
Sent: Tuesday, January 24, 2012 10:54 AM
To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Subject: [mapguide-users] Showing point in map
Hey guys,
I am totally frustrated now. After reconstructing and trying lots of examples to show a damn point in the map I did not get it to work.
The most example codes are offline and the demo project for the "markup feature" does also not work.
Now in the last step I tried to avoid to create the layer programmatically and created it in the Maestro.
But now the code
 featureService.UpdateFeatures(resourceIdentifier, featureCommandCollection, false);
does not throw an exception and does also not work.
Has someone a solution for me - preferred in c# .Net for the Ajax viewer which knowly works?
I can´t believe that it is so hard to show a damn point in the map.
Here is the last way I have tried - (last one of lots before):
    void ShowPoint()
        // Initialize
        InitializeWebTier();
        sessionId = Request.Params["SESSION"];
        mapName = Request.Params["MAPNAME"];
        MgUserInformation userInfo = new MgUserInformation(sessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
        MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
        // Open the map
        MgMap map = new MgMap(siteConnection);
        map.Open(mapName);
        MgBatchPropertyCollection batchPropertyCollection = new MgBatchPropertyCollection();
        String featureSourceName = "Library://test/shapes/POIs.FeatureSource";
         //String featureSourceName = "Library://test/layer/POIs.LayerDefinition";
        MgResourceIdentifier resourceIdentifier = new MgResourceIdentifier(featureSourceName);
        // Make the point
        batchPropertyCollection.Add(MakePoint("Point A", x, y));
        // Add the batch property collection to the feature source
        MgInsertFeatures cmd = new MgInsertFeatures("POIs", batchPropertyCollection);
        MgFeatureCommandCollection featureCommandCollection = new MgFeatureCommandCollection();
        featureCommandCollection.Add(cmd);
        // Execute the "add" commands
        // Saving the map
        map.Save(resourceService);
         //map.save
        string script = "parent.Refresh();";
        ClientScript.RegisterClientScriptBlock(this.GetType(), "Refresh",
            script, true);
        ClientScript.RegisterStartupScript(this.GetType(), "Refresh", "Refresh();");
    MgPropertyCollection MakePoint(String name, double x, double y)
        MgPropertyCollection propertyCollection = new MgPropertyCollection();
        MgWktReaderWriter wktReaderWriter = new MgWktReaderWriter();
        MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
        MgGeometry geometry = (MgPoint)wktReaderWriter.Read("POINT XY (" + x.ToString().Replace(',', '.') + " " + y.ToString().Replace(',', '.') + ")");
        MgByteReader geometryByteReader = agfReaderWriter.Write(geometry);
        MgGeometryProperty geometryProperty = new MgGeometryProperty("Geometry", geometryByteReader);
        //propertyCollection.Add(new MgInt32Property("FeatId", 6));
        propertyCollection.Add(new MgStringProperty("Name", "Name"));
        propertyCollection.Add(new MgGeometryProperty("Geometry", geometryByteReader));
        wktReaderWriter.Dispose();
        agfReaderWriter.Dispose();
        return propertyCollection;
Best Regards
David
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120124/9d903831/attachment.html
