[mapguide-users] Re: Questions for Maestro users on Linux/Mac
Jackie Ng jumpinjackie at gmail.com
Fri Jan 27 05:08:30 EST 2012
Hi Hans,
It will basically be the same code, referencing the same libraries, but
targeting the latest framework and CLR (4.0).
Linq support has been around for quite a while now (since Mono 2.0)
The WinForms + BCL foundation should be well supported by Mono regardless of
framework version if we can accept 2.8 as the baseline minimum version of
Mono (where the 4.0 framework support will have had at least 1 release cycle
of stability and bug fixes)
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Questions-for-Maestro-users-on-Linux-Mac-tp4342196p4342622.html
