[mapguide-users] BaseMap
Douglas Gardim dgardim at gmail.com
Wed Jul 18 17:33:21 PDT 2012
I guess I found something here...
in "fusionSF.js" inside "mapLoaded:function(r)" I have this line of code:
this.groupName = o.groups[0].groupName;  //assumes only one group for now
It is the first time I'm dealing with this fusion code so I'm not very sure
about the whole thing.. But I could see that this o.groups has all the
groups: first the regular layer groups and after those the base layer
groups.. so I changed the code to get the last group:
this.groupName = o.groups[o.groups.length - 1].groupName;  //assumes only
one *base layer* group for now
Well, it works... I havent seen any bad side effects yet.. :)
On Wed, Jul 18, 2012 at 7:41 PM, Douglas Gardim <dgardim at gmail.com> wrote:
> Hi community,
> I'm using MapGuideEnterprise2011, and something weird is happening to my
> base layers.
> I drilled down the problem to this:
> We have a BaseMapDefinition with a couple of BaseMapLayers and a few
> regular MapLayers. In this situation the baselayers work pretty well and
> the tiled map images are generated gracefully.
> <MapDefinition ...>
>   <MapLayer>...</MapLayer>
>   <BaseMapDefinition>
>     <BaseMapLayerGroup>
>       <BaseMapLayer>...</BaseMapLayer>
>     </BaseMapLayerGroup>
>   </BaseMapDefinition>
> </MapDefinition>
> The problem starts when I add a simple empty MapLayerGroup to my
> MapDefinition. When I try to use this configuration my base layers simply
> stop working. The MapLayers continue showing normally, but nothing shows up
> in the BaseMapLayers. The base layers are shown only in the layers list.
> <MapDefinition ...>
> **<MapLayerGroup><Name>New Layer Group</Name>...</MapLayerGroup>**
>   <BaseMapDefinition>
>     <BaseMapLayerGroup>
> </MapDefinition>
> I found that MapGuide has created a "New Layer Group" directory (the name
> of the MapLayerGroup!!) inside the \Server\Repositories\TileCache
> directory, going down the directory tree I see many empty tiled images. It
> seems like it tried to create a tiled map for my MapLayerGroup instead of
> the BaseMapLayerGroup.
> I dont believe it's a bug because using MapLayerGroups together with
> BaseMapLayerGroups seems to be a very common configuration to me.
> Am I missing something here? Have anyone ever experienced something like
> this?
> Thanks in advance!
> DougG
> <mapguide-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120718/e230bfcd/attachment.html>
