[mapguide-users] coordinate conversion 2.4 RC1 (google epsg:3785)
pcardinal pierre.cardinal at sympatico.ca
Sat Jul 21 07:31:58 PDT 2012
Thank you Pierre long live to you! ;-)
 Date: Fri, 20 Jul 2012 23:45:21 -0700
To: pierre.cardinal at sympatico.ca
Subject: Re: coordinate conversion 2.4 RC1 (google epsg:3785)
	If it is for the purpose of showing your map with google/bing/osm layers lining up then, the map should be in WGS84.PseudoMercator, whose wkt is:
PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]
- Jackie
		If you reply to this email, your message will be added to the discussion below:
		http://osgeo-org.1560.n6.nabble.com/coordinate-conversion-2-4-RC1-google-epsg-3785-tp4989752p4989765.html
		To unsubscribe from coordinate conversion 2.4 RC1 (google epsg:3785), click here.
		NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/coordinate-conversion-2-4-RC1-google-epsg-3785-tp4989752p4989791.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120721/7e14af96/attachment.html>
