[mapguide-users] Vaious datasources in one layer
Marcelo Bilezker marcebil at gmail.com
Sun Jul 29 03:37:26 PDT 2012
Hi It is posible to join multiple SDF datasources in only one layer?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
mapguide-users-request at lists.osgeo.org
Sent: Lunes, 23 de Julio de 2012 16:00
To: mapguide-users at lists.osgeo.org
Subject: mapguide-users Digest, Vol 67, Issue 18
Send mapguide-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	mapguide-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of mapguide-users digest..."
Today's Topics:
   1. How to change Bing Map Locale? (hayashi at ogi)
   2. Re: Is there any service interoperability	improvment (Jackie Ng)
   3. failed to load resource error. (ketan7880)
   4. Re: failed to load resource error. (Zac Spitzer)
   5. Re: failed to load resource error. (ketan7880)
   6. Re: failed to load resource error. (Zac Spitzer)
   7. Re: MGOS 2.4 RC1: Quick Plot Scaling Issue (BenjaminZ)
   8. Re: Change taskpane in Fusion? (Ryan Northcott)
   9. Re: Change taskpane in Fusion? (JamesDudden)
  10. MG2.4 Feature Source FDO Error 559 - Connect Failed (geomapper)
Message: 1
Date: Mon, 23 Jul 2012 09:53:05 +0900
Subject: [mapguide-users] How to change Bing Map Locale?
Message-ID: <500CA071.8010708 at apptec.co.jp>
Content-Type: text/plain; charset=ISO-2022-JP
Hi all,
I have a trouble about using "Bing Map" as fusion BaseMap on MGOS2.2.
My country Locale is ja-JP and I set "ja" locale to serverconfig.ini.
I finished to translate MGOS2.2 Fusion to Japanese and Fusion and some my
widgets are working well as Japanese mode.
But "BingMap" is not show Japanese labels on my Fusion contents.
In fact, I tried to add an option string "&mkt=ja-JP" to
"<VirtualEarthScript>http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?
v=6.2</VirtualEarthScript>"
entry by using Mestro5.0beta.
It did not work because I did not save opened XML by Maestro error.
"Openlayes" need "Openlayes.Layer.Bing.culture" to conrol locale on Bing,
But I could not find the line to set this "culture" member value to "ja-JP"
or "en-US" or other language locale value.
Does anyone know how to change BingMap labeling locale on Fusion?
Best regard,
Hayashi.
 OSGeo.JP psc
 http://www.osgeo.jp
 hayashi at apptec.co.jp
Message: 2
Date: Sun, 22 Jul 2012 19:45:08 -0700 (PDT)
Subject: Re: [mapguide-users] Is there any service interoperability
	improvment
Message-ID: <1343011508612-4989947.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Nope. Still only WMS and read-only WFS. Service interoperability is still a
major deficiency of MapGuide.
- Jackie
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Is-there-any-service-interoperability-im
provment-tp4989806p4989947.html
Message: 3
Date: Sun, 22 Jul 2012 21:19:17 -0700 (PDT)
Subject: [mapguide-users] failed to load resource error.
Message-ID: <1343017156823-4989954.post at n6.nabble.com>
Hi
When I am trying to view my webpage with flexible layout is unable to load
any data from map, even same from Maestro. (unable to load data in flexible
layout) Layout is loading up fine it's just data.
Map is viewing file from Maestro.
I am not getting any error msg but I found out this,
*"PHP Notice:  Trying to get property of non-object in C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\layers\MapGuide\php\Utilities.php on
line 641"*
don't know what that means.
Regards,
http://osgeo-org.1560.n6.nabble.com/failed-to-load-resource-error-tp4989954.
html
Message: 4
Date: Mon, 23 Jul 2012 14:47:05 +1000
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Subject: Re: [mapguide-users] failed to load resource error.
Message-ID:
	<CAArGWaRKsMarG=xvBwgAcQ-ucwfSWFamMm4bBh1X5qZ4eDusOw at mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
So you have a line number and an error, did you have a look into
Utilities.php?
On Mon, Jul 23, 2012 at 2:19 PM, ketan7880 <ketan7880 at gmail.com> wrote:
> Hi
flexible
> line 641"*
> Regards,
html
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Message: 5
Date: Sun, 22 Jul 2012 21:50:18 -0700 (PDT)
Message-ID: <1343019018349-4989957.post at n6.nabble.com>
I did and it's look like this...
       * $name = $nameElt->item(0)->nodeValue;*
I am not sure what to do with this.
Regards,
http://osgeo-org.1560.n6.nabble.com/failed-to-load-resource-error-tp4989954p
4989957.html
Message: 6
Date: Mon, 23 Jul 2012 15:15:05 +1000
Message-ID:
	<CAArGWaS9qNuLLzXstJPUJw=QWzsLyS44Qp9xGfHO2L3HYYR7cg at mail.gmail.com>
btw, please always mention the version of mapguide / fusion you are using
http://trac.osgeo.org/fusion/browser/branches/fusion-mg24/layers/MapGuide/ph
p/Utilities.php#L641
reading around the code, it points to a problem with a specific layer
you could try making a copy of the map and removing layers one by one
to identify
which one is failing?
z
> Regards,
4989957.html
Zac Spitzer
+61 405 847 168
Message: 7
Date: Mon, 23 Jul 2012 01:30:33 -0700 (PDT)
Subject: Re: [mapguide-users] MGOS 2.4 RC1: Quick Plot Scaling Issue
Message-ID: <1343032233590-4989992.post at n6.nabble.com>
Now it works fine. It was a mistake from me when I Integrated the code in
fusion.SF to compile. Thanks for the good function!
http://osgeo-org.1560.n6.nabble.com/MGOS-2-4-RC1-Quick-Plot-Scaling-Issue-tp
4988171p4989992.html
Message: 8
Date: Mon, 23 Jul 2012 09:42:08 -0400
Subject: Re: [mapguide-users] Change taskpane in Fusion?
Message-ID:
	<CADLoUoY1sH5WVW1qjvQRTQ7796FMrZgRqqcAuOaRC3DkR_LWng at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Here is the xml in my taskpane widget.
<?xml version="1.0" encoding="utf-8"?>
<WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <Name>TaskPane</Name>
  <Type>TaskPane</Type>
  <Location />
  <Extension>
    <MenuContainer>TaskMenu</MenuContainer>
 *   <InitialTask>../../../../../MapStart.aspx</InitialTask>*
  </Extension>
</WidgetType>
On Fri, Jul 20, 2012 at 7:29 AM, JamesDudden
<jamesdudden at blueyonder.co.uk>wrote:
> You're right there is a taskpane tab when using MG Studio but I need to be
> able to do this using Maestro.
> Any other ideas?
http://osgeo-org.1560.n6.nabble.com/Change-taskpane-in-Fusion-tp4989594p4989
600.html
URL:
<http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120723/dd66ad
7b/attachment-0001.html>
Message: 9
Date: Mon, 23 Jul 2012 07:26:31 -0700 (PDT)
From: JamesDudden <jamesdudden at blueyonder.co.uk>
Message-ID: <1343053591257-4990098.post at n6.nabble.com>
Excellent, got it working - thanks very much.
http://osgeo-org.1560.n6.nabble.com/Change-taskpane-in-Fusion-tp4989594p4990
098.html
Message: 10
Date: Mon, 23 Jul 2012 11:46:10 -0700 (PDT)
Subject: [mapguide-users] MG2.4 Feature Source FDO Error 559 - Connect
	Failed
Message-ID: <1343069170659-4990167.post at n6.nabble.com>
Greetings,
I am currently running MG Version 2.4 x64 on IIS running PHP, which I have
just upgraded to from MG 2.2. My problem is due to a number of data
connections which were previously working properly, but now appear to be
broken or improperly linked.
Below is the error message given by the log files when I tried to "Test
Connection" for an SDF Feature Source in Maestro (I recieve similar messages
when trying all other data connection types too):
<2012-07-23T09:26:55> 	2016	MapGuide Maestro v4.0.1.6639	127.0.0.1
Administrator
 Error: An exception occurred in FDO component.
        Error occurred in Feature Source
(Session:ea537b66-d4e1-11e1-8000-005056b67e2c_en_MTI3LjAuMC4x0AFC0AFB0AFA//8
b9df030-9b59-49b5-a02e-f1744f1a87bb.FeatureSource):
        SDF connect failed. File does not exist or cannot be opened in
specified access mode.
        - MgFdoConnectionManager.Open() line 333 file
c:\mg-2.4-x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
        - MgFdoConnectionManager.CacheFdoConnection() line 1099 file
        - MgFdoConnectionManager.Open() line 1091 file
         (Cause: , Root Cause: )
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute() line 100 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\OpTestFeatureSourceConnectio
n.cpp
  - MgServerFeatureService.TestConnection() line 243 file
c:\mg-2.4-x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
  - MgFdoConnectionManager.Open() line 368 file
>From what I understand, my main issue is that the files mentioned in the
error message actually do not exist on my computer, as I have been unable to
locate them. I have also checked the FDO directory in the MapGuide
installation, and all of the correct DLLs appear to be there, as well as the
providers.xml document which looks correct. I am presuming either an error
on my part when installing MG2.4, or an error with the 2.4 installer on my
machine is to blame; although I believe the former to be more possible since
I am still new to MGOS. On that note, my apologies if this is a trivial
error.
Can anybody please advise me about what the next best steps to take would
be?
Sincerely,
Thom
http://osgeo-org.1560.n6.nabble.com/MG2-4-Feature-Source-FDO-Error-559-Conne
ct-Failed-tp4990167.html
End of mapguide-users Digest, Vol 67, Issue 18
