[mapguide-users] Can you add a layer with XY coordinates to a Bing maps layer?
JamesDudden jamesdudden at blueyonder.co.uk
Fri Jun 1 02:00:00 PDT 2012
I have added a Bing map base layer which uses the WGS84.PseudoMercator
coordinate system. Can I add a layer with XY coordinates that will marry up
with the Bing layer.
The layers in question are as follows:
UK layer using the British National Grid coordinate system
Point layer themed with symbols using XY coordinates stored in an Access
database.
At the moment I can get them both to work on their own but would like to
know if it's possible to combine them?
Any help is appreciated.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Can-you-add-a-layer-with-XY-coordinates-to-a-Bing-maps-layer-tp4978484.html
