[mapguide-users] mapguide OS 2.2 or 2.4 with IIS and .NET Framework 4
Johnnie GIS johnniegis at gmail.com
Tue Jun 26 22:07:14 PDT 2012
It is definitely possible to use MGOS 2.2 with the tools you have indicated. The difference for the setup we have used is that the MapGuide directory resides as a sub of the .Net MVC project. This allows each site to have individual settings.
I haven't seen your particular error but I can check at work and see I anyone else has.
Regards,
Jonathon
Sent from my iPhone, please excuse any typos.
On Jun 26, 2012, at 9:52 AM, snrt100 <cazador_estm at hotmail.fr> wrote:
hello everyone
I have a very important question!
I want to use mapguide os 2.2 with MVC 3 or 2 and framework entitity
technology. NET
is that possible?
ideas please!
example:
I have an ASP.Net MVC project with 2 Entity Framework, JSON, jqGrid and
JQuery works very well,
http://jetmathew.wordpress.com/2011/03/02/asp-net-mvc-2-with-entity-framework-json-jquery-and-jqgrid/
Link
Step 1: I put the project in the "OSGeo \ MapGuide \ web \ www"
Step 2: After I create the virtual directory in IIS 5.1 service, pointing to
the ASP.NET project
Step 3: in visual studio 2010, I import the web project and I build the web
site
*it gives me this error:*
Error 1 The value of the attribute 'compilerVersion' in the provider options
should be 'v4.0' or later if you compile for version 4.0 or later. NET
Framework. To compile the Web application for version 3.5 or earlier. NET
Framework, remove the attribute 'targetFramework' <compilation> element of
the Web.config file.
View this message in context: http://osgeo-org.1560.n6.nabble.com/mapguide-OS-2-2-or-2-4-with-IIS-and-NET-Framework-4-tp4984010.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
